KB47607
Published: April 24, 2006
Revision: 4.0
OptoDisplay and ioDisplay object dimensions are limited to 999 when entered in the Graphic Dynamic Attributes window
ioDisplay Professional
ioDisplay Basic
FactoryFloor Software - OptoDisplay
Problem was discovered in version: OptoDisplay R4.1a / ioDisplay R6.1a
Problem is corrected in version: ioDisplay R7.0a
When a graphic is resized in the Graphic Dynamic Attributes window of OptoDisplay or ioDisplay Configurator, the maximum width (W:) and height (H:) is 999.
To set dimensions greater than 999 for the width (W:) and height (H:), use the graphic’s sizing handles.
  1. Select a graphic with the Select tool.
  2. Position the pointer over a square handle, click, drag, and release when the object is the size you want.
  3. Sizes over 999 are now kept.
Opto 22 has corrected the described behavior in ioDisplay. The object dimension limits have been changed to 99,999.
