KB47789
Published: April 25, 2006
SNAP-AIVRMS and SNAP-AIARMS module readings may become fixed at -32768
SNAP-AIVRMS
SNAP-AIARMS
SNAP-AIVRMS and SNAP-AIARMS module readings may become fixed at -32768. The low scale for these modules is zero, and they should not report negative values that are less than 0.5% of full scale (-1.25 V for the SNAP-AIVRMS module, and –50 mA for the SNAP-AIARMS module), unless there is an error condition.
Module firmware has been updated to correct this problem. If you are experiencing the above symptoms, contact Opto 22 Product Support to discuss a solution.
