KB47872
Published: April 25, 2006
Revision: 4.0
Digital points may not be available to ioDisplay Historic Data Logs
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
Digital input and output points are not visible from ioDisplay Configurator when trying to configure a Historic Data Log. Because the points under Item Name are not visible in the Value Tag Selection Dialog, they cannot be added to a Historic Data Log.
[image1]
