KB47890
Published: May 1, 2006
Revision: 4.0
Invalid analog readings possible while erasing and writing to flash memory on Ethernet-based I/O units
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-LCE
SNAP-B3000-ENET
SNAP-ENET-S64
Problem was discovered in version: R6.1a
Problem was fixed in version: R7.1a
Analog input point values of –1.#QNAN may be returned if the I/O unit is also executing commands that erase and write to flash memory. This can occur, for example, while running an ioControl strategy, and when the I/O unit is accessed by ioManager or ioTerminal.
