KB47922
Published: April 24, 2006
Revision: 4.0
ioControl allows assignment of a larger than 32-bit number to an Integer 32 variable
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
The Move command in ioControl allows a number that is greater than 32 bits, to be moved to an Integer 32 variable. A -13 overflow error occurs when the strategy is downloaded to a controller.
Change the number to a 32 bit or smaller number, or use a 64 bit integer variable.
