KB47958
Published: February 26, 2007
From OptoControl, Ethernet-based I/O units may go offline if number of characters waiting not checked before receiving characters
SNAP-LCM4
M4RTU
M4
M4 I/O
Problem was discovered in firmware version: R4.1c
Resolution is included in beta version: B4.1d, Build February 14, 2007
Error –44 is unexpectedly reported in the OptoControl error queue, and Ethernet based I/O units may go offline without reporting an error to the queue. OptoDisplay may exhibit unexplained timeouts, and OptoEnetSniff may not show communication transaction errors.
Use the “Get Number of Characters Waiting on Ethernet Session” command immediately before using the “Receive N Characters from Ethernet Session.” When designating the number of characters to receive, make sure the number is greater than 0, and up to the number of characters waiting.
