KB48089
Published: April 25, 2006
Revision: 4.0
PID ‘forced value’ parameter may be limited by ioControl
ioControl Professional
ioControl Basic
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
A PID output’s ‘forced value’ parameter may be limited by ioControl when the input is under-range. In this example, the output value has a lower clamp of 60, and an upper clamp of 100. When the input is under-range, the desired output is 80, however, ioControl reports the value is invalid.
[image1]
This problem has been resolved.
