KB48313
Published: November 11, 2008
Optomux High Resolution Square Wave command and E1 brain boards
E1
Problem was discovered in version: R1.1b
Problem is fixed in version: R1.1c
The High Resolution Square Wave command (Optomux command Z) returns a short on data error N05 when used with the E1 brain board.
Make the length of the M modifier parameter 4 bytes.
