KB48507
Published: April 24, 2006
Volt-Amp and power readings from SNAP-AIPM modules are partial scale
The values reported for Watts (point 3 on the module) and Volt-Amps (point 4 on the module) from SNAP-AIPM modules are only 90.9% of the actual value. The voltage reading on point 1 multiplied by the current reading on point 2, should equal the VA reading from point 4.
Opto 22 has corrected this issue. If you are experiencing the above symptoms, contact Opto 22 Product Support to discuss your problem’s circumstances and to request a return RMA to correct your module.
