KB48510
Published: April 24, 2006
Revision: 4.0
SNAP-B3000-ENET may reset under particular high speed I/O conditions and high speed SNAP-IDC5Q counting
SNAP-B3000-ENET
Problem was discovered in version: R6.1a firmware
Problem is corrected in version: R7.0a firmware
Rapid I/O activity on a rack with a SNAP-B3000-ENET and a SNAP-IDC5Q, may cause the SNAP-B3000-ENET to reset. The symptoms are more likely to occur if the SNAP-IDC5Q is installed in a module position that is further away from the brain board.
