KB48542
Published: April 25, 2006
ioDisplay and High Density Digital module point access
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R6.1a
Problem is fixed in version: R7.0a
ioDisplay cannot access High Density Digital module points on a SNAP-UP1-ADS or SNAP-UP1-M64 that is configured with the loopback IP address (127.0.0.1).
Configure the Ultimate I/O unit with a valid IP address that is not the loopback address.
