KB48677
Published: April 25, 2006
‘Enable Communication to I/O Unit’ command and restoring I/O configuration in ioControl
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: Firmware R6.1a
Problem was corrected in version: Firmware R7.0a
The Enable Communication to I/O Unit command in ioControl does not reconfigure an Ethernet I/O unit that has recovered from a power loss. When power is restored to the Ethernet I/O unit, the configuration is set to the default settings. This results, for example, in analog points not having proper scaling, and digital outputs that are configured as inputs.
Save the I/O unit configuration settings to the Flash EEPROM by including the Write I/O Unit Configuration to EEPROM command in an initialization chart in ioControl. The configuration is stored to the I/O unit’s permanent memory, eliminating the dependency on the control engine for configuration.
