KB48743
Published: July 10, 2007
OptoTerm crashes when inspecting controllers with Cyrano firmware, or controllers in loader mode
FactoryFloor Software - OptoTerm
Problem was discovered in version: OptoTerm R4.1a using, OptoCom.dll 4.1.2.0
Problem is fixed in version: OptoCom.dll 4.1.2.1
OptoTerm crashes if a controller with Cyrano firmware, or a controller that is in loader mode, is inspected.
Opto 22 has resolved this issue. Download OptoTerm R4.1b.zip. Unzip the file and install OptoTerm using Setup.exe. Or you can open the Tools folder and run OptoTerm from there.
