KB48938
Published: April 25, 2006
Mismatched I/O module configuration may affect SNAP-UP1-M64 startup
SNAP-UP1-M64
Problem was discovered in version: Firmware version R6.1c
Problem is resolved in version: Firmware version R7.0c
If the I/O modules installed on a rack with a SNAP-UP1-M64 do not match what is configured in an ioControl strategy, the I/O unit will not be enabled when the strategy is started.
Enabling the I/O unit from ioControl Debug mode successfully enables the unit.
