KB49125
Published: July 9, 2009
Revision: 4.0
FactoryFloor patch for PCI ARCNET support
FactoryFloor Software
Problem exists in versions: R4.0c through R4.1a
A patch providing PCI20 ARCNET card support is available from the Opto 22 web site. Download theFactoryFloor patch for PCI ARCNET card from the Application section of our Support page.
Note: It is very important to follow the instructions in the order listed. Do not use Contemporary Controls files or any of the Windows network drivers.
- After downloading the patch, unzip the file to C:\Opto22\temp on your computer.
- Uninstall the existing version of FactoryFloor by going to Start→Control Panel→Add or Remove Programs. Select Opto 22 FactoryFloor x.x, where x.x is the version, and click Remove.
- While still in Control Panel’s Add or Remove Programs, observe if a prior version of the PCI20 Adapter card files have been installed by looking for an entry entitled PCI20 Arcnet R1.0a (for FactoryFloor).
- If it exists, highlight it, select Remove the installation, exit Control Panel, and proceed with step 4.
- If it does not exist, close Add or Remove Programs, exit Control Panel, and proceed with the next step.
- Using Windows Explorer, search for the windrvr.sys file and, except for the one you just unzipped and placed in C:\Opto22\temp, delete all other occurrences of the file from your computer.
- Next, search C:\WINDOWS\INF for oem#.inf files, where # is a number. Open each oem#.inf file, as you search for files associated with the PCI20 ARCNET card. If a file is found, delete it and its corresponding oem#.pnf file.
Note: The Windows root directory may vary based on the operating system used on your computer.
The following are examples of what the oem#.inf file for the PCI20 ARCNET card will look like when you open them:
[image1]
[image2]
- Shut down the computer.
- Remove the PCI20 card from the computer if it was already installed.
- Power up the computer (without the PCI20).
- Install FactoryFloor R4.0c or newer.
- Run the appropriate batch file for the operating system on your computer. From Step 1, these files are located in C:\Opto22\temp.
Operating System
Batch File Name
WinXP, Win2k, WinME, and Win98
XP_2K_ME_98_install.bat
WinNT 4.0
NT_install.bat
Win95
95_install.bat
- A New Hardware Wizard window will start up. Select No, not this time when prompted for Windows Update to search for software, and click Next.
Note: The following screen captures are from a computer with Windows XP. Your windows may vary, based on the operating system and version you are using.
[image3]
Select Don’t search I will choose the driver to install and click Next.
[image4]
- Select Have Disk when prompted to select the device driver you want for this hardware.
[image5]
- Click Browse from the Install from Disk window.
[image6]
- The Locate File window appears.
- Navigate to C:\Opto 22\temp, where you unzipped the patch file. Select the windrvr.sys file, and click Open. If you don't see the windrvr.sys file, change the default file extension type displayed, (*.inf in the File name field) by typing *.* in the File name field and then press Enter on the keyboard. You should now be able to see the windrvr.sys file. Select the file and click Open.
- Click OK from the Install from Disk window.
- Select Next to continue the installation.
[image7]
- Click Finish to complete the installation.
[image8]
- Install the PCI20 ARCNET card into the computer, and power up the computer.
- The Found new hardware message appears. You may have to run the Found New Hardware Wizard twice in order to install the virtual driver (wd_virtual.inf), and the PCI ARCNET driver. The PCI ARCNET driver file name is based on the card model name, followed by ".inf." An example is "pci20_cxs.inf." The drivers are found in the C:\Opto22\temp directory where you unzipped the patch.
- Connect your controller to the ARCNET card with a coaxial cable and test communication between the controller and computer using OptoTerm or OptoControl.
Use this patch if you need ARCNET support.
