KB49213
Published: April 24, 2006
SNAP-AIPM true power reading changes +/- signs
Systems with stable loads and negative true power readings, exhibit a changing +/- sign. The magnitude of the reading is constant, but the sign changes.
Opto 22 has corrected this issue so that the sign remains constant. If you are experiencing the above symptom, contact Opto 22 Product Support to discuss your system’s circumstances and to request a return RMA to correct your module.
