KB49424
Published: April 25, 2006
Load cell commands in ioControl change when added to a strategy
Problem was discovered in version: R7.0a
Problem is fixed in version: R7.0c
The Set Analog Load Cell Fast Settle Level and Set Analog Load Cell Filter Weight commands in ioControl change to the Set All Target Address States and Get Target Address State commands, respectively, when OK is clicked from the Add Instruction dialog window.
