KB49525
Published: April 21, 2006
The ioDisplay ‘Send Discrete’ dynamic attribute Bit field
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.0a
Problem is fixed in version: R7.0b
Projects upgraded to ioDisplay R7.0a and that do not have a Bit number specified in the Send Discrete, Discrete Tag Selection Dialog, will have all 32 bits (bits 0-31) of the selected tag affected by the Fixed Data option. This can lead to unexpected results.
[image1]
Specify a bit number in the Discrete Tag Selection Dialog window Bit field.
Opto 22 has corrected this issue. If a project is upgraded from a version prior to version R7.0, and a bit was not specified in the Bit field, the default bit 0 will be used.
