KB49750
Published: July 2, 2008
Easy OPC VB Forms may cause OptoOPCServer problems
OptoOPCServer
Problem was discovered in version: R7.0a
Problem is fixed in version: R7.0b
Client programs using the automation interface, Easy OPC VB Forms (OptoOPCAuto.dll), may cause OptoOPCServer to fail if an item is added as inactive and later activated. In addition, client programs could not modify the update rate for a group. Attempting to change it set the update rate to 20 ms.
