KB49807
Published: April 25, 2006
OPC clients accessing unavailable string tag types, may affect updates in OptoOPCServer
OptoOPCServer
Problem was discovered in version: R7.0a
Problem is corrected in version: R7.0c
Adding a non-existing ioControl string tag or string table to an OPC client, and performing a synchronous read, causes other tags associated with the same device to stop updating (subscription services). Previously configured tags to the same device that had reported ‘good quality’, stop updating. The non-existing string tag or table will report the data quality as ‘Bad—Device Failure.’
