KB49822
Published: December 12, 2007
Alarm Point notification option's Enabled checkbox becomes grayed out
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R8.0a PAC Display, R7.0a ioDisplay
Problem is fixed in version: R8.1e PAC Display, R7.2h ioDisplay
After setting up an alarm point with an Alarm or Acknowledge Notification Option in ioDisplay and PAC Display Configurator and the Alarm Point dialog is closed and reopened, the Notification Option is not selectable.
[image1]
To change the enabling or disabling of the Notification Options, click on the Alarm or Acknowledge button, and then click OK from the Acknowledge Notification dialog. The checkbox is no longer grayed out and the option can be changed.
