KB49853
Published: April 10, 2006
Numeric Table Element Bit Clear/Bit Set commands in ioControl with persistent tables
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was introduced in version: R7.0a
Problem is fixed in version: R7.1a
The Numeric Table Element Bit Clear and >Numeric Table Element Bit Set commands in ioControl do not work with persistent tables. Using the commands with persistent tables causes an error –29 in the control engine error queue.
