KB49909
Published: April 27, 2006
Analog input filter weight goes to zero when ioControl strategy is run
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-LCE
Problem was discovered in version: R6.0a
Problem is fixed in version: R7.1a
Setting the filter weight with command Set Analog Filter Weight on an analog input in ioControl, results in a filter weight value of zero when the strategy is run.
Analog inputs on I/O units configured by the above listed control engines, will also exhibit the described symptoms. This includes the SNAP-B3000-ENET and SNAP-ENET-S64 I/O units, as well as SNAP-UP1-ADS and SNAP-UP1-M64 units used as I/O units.
