KB50118
Published: April 24, 2006
Windows dynamic attribute and password protected windows in OptoDisplay
Problem was discovered in version: R4.1a
The operator driven “Windows” dynamic attribute, does not check if a window was successfully opened when used with password protected windows. As an example, a graphic in a window is configured to open a password protected, pop up window and also to close itself. If the graphic is clicked, the password prompt appears. However if the prompt is canceled, the pop up window is not opened and the original window with the graphic is also closed.
Opto 22 is aware of this issue.
