KB50148
Published: April 12, 2006
Deleting and undeleting an ioDisplay alarm may affect alarm points
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.0c
Problem is fixed in version: R7.0f ioDisplay Professional
R7.0e ioDisplay Basic
Deleting an ioDisplay alarm graphic and then selecting the Edit→Undo Add Alarm option causes unexpected results. The following are examples of symptoms that can occur:
1. Alarm points that were assigned to the alarm, appear but are not active.
2. The tag reference count for alarm points is not accurate.
Delete the alarm, create a new alarm, and recreate the alarm configuration for it.
