KB50153
Published: April 19, 2006
Controller will not boot up properly after storing strategy to flash
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R6.1c
Problem is fixed in version: R7.1a
The control engine resets shortly after booting up.
Use the control engine’s ‘Reset to factory defaults’ jumper to clear the problem.
