KB50210
Published: March 16, 2006
Testing IP address assignment in ioManager
Problem was discovered in version: R7.0c
Problem is fixed in version: R7.1a
Setting the IP address with ioManager Tools→Assign IP, and then testing it with the Test button, causes the command prompt window to flash briefly and then disappear. Results of the test cannot be determined.
Symptoms occur when two or more devices appear in the MAC To IP Address Mappings display area, and at least two devices are shown in the Units Requesting IP Addresses display box.
[image1]
