KB50224
Published: July 5, 2006
Renaming expanded numeric or string tables used in ioControl and OptoControl watch windows
ioControl Professional
ioControl Basic
FactoryFloor Software - OptoDisplay
Problem was introduced in version: ioControl R1.0a, OptoControl R3.0a
Problem is resolved in version: ioControl R7.1a, OptoControl R4.1d
Renaming an expanded numeric or string table used in a watch window, causes an error when switching into debug mode. The error prevents going into debug mode, and an error message similar to the following is displayed:
[image1]
Rename the numeric or string table variable back to the original name, or delete the original watch window and create a new watch window with the renamed table name.
