KB50238
Published: September 8, 2006
Under certain conditions, manually enabling I/O unit from ioControl debug mode may cause problem
Problem was discovered in version: R7.0c
Problem is resolved in version: R7.1a
Manually enabling an I/O unit from ioControl Debug mode could cause the control engine to stop responding. Specifically, if the following method was executed: without a strategy running in debug mode, enable an I/O unit, clear RAM, download the strategy, and then enable the I/O unit from debug mode again.
