KB50281
Published: April 11, 2006
Running maximum number of charts and Call Chart command on ioControl control engines
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was introduced in version: R1.0
Problem is resolved in version: R7.1a
If the ioControl Call Chart command is executed while the maximum number of charts are already running, the control engine may hang or reset.
Verify your control engine is running one chart less than the maximum number of charts it can manage. This allows the Call Chart to execute successfully.
