KB50296
Published: March 14, 2006
Serial B3000 with configured analog input module not on the mounting rack
Problem was introduced in version: Original release
Problem is resolved in version: 81.35 firmware
If a serial B3000 is configured with an analog input module that is not physically installed on the mounting rack, readings on a different analog input module could intermittently be incorrect.
