KB50621
Published: September 7, 2006
Pre R7.0 ioControl strategies and PID loop’s Output Maximum Change Rate
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.0c
Problem is resolved in version: R7.0d
ioControl strategies prior to version R7.0a, would have the PID loop’s Output Maximum Change Rate changed to 0 when imported into a newer version of ioControl.
