KB50622
Published: September 7, 2006
ioControl Replace feature may have unexpected results if OptoScript code ends in newline
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.0c
Problem is resolved in version: R7.0d
The ioControl Configurator Replace feature (Edit→Replace) does not work correctly if an OptoScript block has lines ending with only a newline (‘\n’) character.
Example:
Search for:
“Analog_IO_Unit_Pointer”
Replace with:
“Analog_IO_Unit_Pointer_2”
Produces:
“AnAnalog_IO_Unit_Pointer_2”
It was also possible for ioControl to lock up (a constant hourglass appears) when trying to correct the incorrect replacement results.
