KB50623
Published: August 1, 2006
The ioControl ‘Replace’ function does not indicate changes made to OptoScript code
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.0c
Problem is resolved in version: R7.0d
If the Replace function is used in ioControl Configure mode to make changes within OptoScript code, the strategy is not being marked as needing to be compiled.
