KB50694
Published: June 26, 2006
OptoControl analog point scaling configuration is not overwritten by the ioManager .otg file
FactoryFloor Software - OptoControl
Problem was discovered in version: R4.1a
An imported ioManager configuration file (.otg file) with a scaled analog point does not overwrite the same, previously configured, non-scaled analog point in OptoControl.
Opto 22 is aware of this issue.
