KB50824
Published: June 22, 2006
Problems with moving analog points on a serial B3000 in ioControl
ioControl Professional
Problem was introduced in version: R7.0a
Problem is resolved in version: R7.1b
Moving analog points on a serial B3000 brain may cause problems. In some situations, ioControl does not allow a point to be moved to all available positions. In other situations, it incorrectly allows moving a point to a module with a different measurement type (e.g. moving a voltage input into a current input).
