KB50922
Published: July 11, 2007
OptoTerm crashes when downloading Forth or controller download files
FactoryFloor Software - OptoTerm
Problem was discovered in version: OptoTerm R4.1a using, OptoCom.dll 4.1.2.0
Problem is fixed in version: OptoCom.dll 4.1.2.1
OptoTerm crashes when attempting to download a Forth file (*.crn) using File→Download Controller Forth File, or a controller download file (*.cdf), using File→Download Controller Download File.
Opto 22 has resolved this issue. Download OptoTerm R4.1b.zip. Unzip the file and install OptoTerm using Setup.exe. Or you can open the Tools folder and run OptoTerm from there.
