KB51004
Published: May 4, 2006
SNAP-PAC-S1 and disabling of mistic digital outputs in ioControl
SNAP-PAC-S1 Controller Firmware
Problem was discovered in version: R7.1a
Resolution is included beginning in beta version: B7.1d
Problem is fixed in version: R7.1d
After disabling a digital output on a mistic (serial) I/O unit from a SNAP-PAC-S1, the XVAL and the physical point continue to react to some digital output commands. The commands are:
  • Generate N Pulses
  • Start Continuous Square Wave
  • Start Off-Pulse
  • Start On-Pulse
  • Resolution:
