KB51029
Published: November 26, 2007
Changes from string literal to null string not saved by PAC Control and ioControl string commands
PAC Control Professional
PAC Control Basic
ioControl Professional
ioControl Basic
Problem was discovered in version: R8.0a PAC Control, R5.1a ioControl
Problem is fixed in version: R8.1c PAC Control
Attempting to change a PAC Control or ioControl string command that uses a string literal to an empty string does not retain the changes. It continues to display the original string.
Example: Use the Move String command to move a literal string “abc” to a string variable. Click OK to close the Add Instruction dialog window. With the command highlighted, click the Modify button, and modify the string to remove “abc.” An empty null string literal is in the From: parameter. Click OK, and the original string “abc” is still present in the Move String instruction.
Opto 22 has resolved this issue for PAC Control.
