KB51068
Published: May 1, 2006
Using ‘Is I/O Unit Ready?’ on a restarted I/O unit causes lock up
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.1c
Problem is resolved in version: R7.1d
Attempts to reconnect to an Ethernet I/O unit when a prior attempt failed, may cause problems and require a power cycle. In ioControl, if the Is I/O Unit Ready? command is used, error code -17, "Port already locked", is added to the error queue.
