KB51157
Published: January 3, 2007
ioDisplay unresponsive from corrupt Symbol Factory graphic
ioDisplay Professional
ioDisplay Basic
Problem was discovered in version: R7.1c
Temporary workaround in version: R7.1d
Problem is resolved in version: R7.1g
ioDisplay may become unresponsive after importing a corrupt 3dSymbol graphic from Symbol Factory.
To verify the problem, from ioDisplay Configurator go to Edit→Paste from File→Built in symbols. Browse to ioDisplayProSupportFiles, 3dSymbol, and select Tocpidfp.smb. A message appears stating: ‘Symbol File is from a previous version of ioDisplay or OptoDisplay.. Save to File to update.’ After clicking ‘OK’, ioDisplay becomes unresponsive, and ioDisplay must be terminated.
Do not use the Tocpidftp.smb graphic in affected versions. The corrupt graphic was removed from the 3dSymbol subfolder until the issue was resolved.
