KB51181
Published: July 6, 2007
Config EEPROM ‘Set’ button in PAC Control / ioControl Debug mode disables I/O unit
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.0c
Problem is fixed in version: R8.0a SNAP PAC firmware, R7.2d Ultimate I/O firmware
During a stopped strategy in ioControl debug mode, if the Config EEPROM Set button is clicked, the I/O unit becomes disabled and does not re-enable. Errors –26, –534, and –8612 are added to the controller error queue. Attempting to re-enable the I/O unit adds error -8612 to the queue. Re-starting the strategy or cycling power to the I/O unit does not re-enable the I/O unit. Only cycling power to the controller re-enables the I/O unit.
While ioControl cannot communicate to the disabled I/O unit, ioManager is able to inspect the I/O unit without a problem.
[image1]
