KB51388
Published: July 5, 2006
GetValueFromName ioControl command may cause –12 error
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.0c
Problem is resolved in version: R7.1f
Corrected potential problem with ioControl command GetValueFromName when the named variable, passed in the first parameter to this command, was a table element. A possible incorrect error –12 could be returned as the status code.
