KB51414
Published: January 11, 2008
Incorrect string length written to scratchpad register with OptoMMP Communication Toolkit, ActiveX example
Problem was discovered in version: R2.0a
Writing an ASCII string with the ActiveX ‘Scratch Pad.exe’ example, writes a string length that is one greater than the actual length to the scratchpad register. The method used to write the ASCII string is SetScratchPadStringArea().
