KB51758
Published: January 4, 2007
The Send Value ‘Offset’ feature in ioDisplay not working as expected
ioDisplay Professional
ioDisplay Basic
Problem was found in version: R7.1b
Problem is fixed in version: R7.1g
The Offset feature in the Send Value dynamic attribute does not work as expected. The Offset value should be added to the tag’s current value, but instead the current value plus the offset is added each time.
[image1]
