KB51833
Published: October 20, 2006
Changes to SNAP-PAC-R1 and SNAP-PAC-R2 Scanner Flags have no effect
SNAP-PAC-R1 Controller Firmware
SNAP-PAC-R2 Controller Firmware
Problem was discovered in version: R7.1d
Problem is fixed in version: R7.1g
Changes to SNAP-PAC-R1 and SNAP-PAC-R2 Scanner Flags have no effect on the parameters they are meant to change. For example, setting the Scanner Flag to ‘2’ should disable the analog scanner, but it does not.
From ioManager, the memory location for the Scanner Flags can be accessed from Tools→Inspect→Status Write.
[image1]
