KB51899
Published: January 5, 2007
Unable to set SNAP-AILC parameters from ioManager
ioManager
Problem was introduced in version: R7.0b
Resolution is included beginning in beta version: B7.1c
Problem is fixed in version: R7.1c
Changes from ioManager to the “Load Cell Fast Settle Level” and “Load Cell Filter Level” parameters for the SNAP-AILC module, are not sent to the brain.
Note: The load cell parameters are accessed in ioManager through Tools→Inspect, Point Config.
Opto 22 has resolved this issue. It is also necessary to update the brain firmware in order to retain the load cell parameter changes when storing to flash. Refer to OptoKB KB51834 for more information.
