KB52053
Published: June 16, 2006
SNAP-PAC-R2s configured in ioControl as I/O units may behave unexpectedly
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R7.1e
Resolution is included beginning in version: R7.1f
I/O units configured in ioControl as ‘Type: SNAP-PAC-R2’ may behave unexpectedly because the point configuration information is not sent by the control engine to the SNAP-PAC-R2. The unexpected behaviors include outputs not turning on, scaling, and other point or I/O Unit configuration parameters having no effect.
[image1]
Upgrade all control engine firmware to version R7.1f or newer in order to use a SNAP-PAC-R2 as an I/O unit in an ioControl strategy. This includes firmware on a SNAP-PAC-R2 if it is running a strategy referring to its own I/O, or the I/O on another SNAP-PAC-R2. This also applies to the other control engines listed above that are running ioControl strategies referencing SNAP-PAC-R2s.
