KB52178
Published: December 20, 2006
Some OptoScript commands used with Integer 64 may cause unexpected controller behavior
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.1d
Problem is fixed in version: R7.1e
The following OptoScript commands may cause a control engine to reset or have strange behavior if an Integer 64 is passed to any of the parameters named "Module #", "Point #", "Start Index", "Start Table Index", or "Clear Mask".
    GetHddModuleStates GetClearAllHddModuleOffLatches
    GetHddModuleOnLatches ClearHddModuleOnLatches
    GetHddModuleOffLatches ClearHddModuleOffLatches
    GetClearHddModuleOnLatches SetHddModuleFromMomo
    GetClearHddModuleOffLatches TurnOnHddModulePoint
    GetAllHddModuleStates TurnOffHddModulePoint
    GetAllHddModuleOnLatches GetHddModuleCounters
    GetAllHddModuleOffLatches GetClearHddModuleCounters
    GetClearAllHddModuleOnLatches GetClearHddModuleCounter
