KB52179
Published: June 19, 2006
Reference to a PID by another PID may cause an ‘Undefined command’ error in ioControl
ioControl Professional
ioControl Basic
Problem was discovered in version: R7.1d
An ioControl strategy with two PIDs that reference each other may cause an ‘Undefined command’ error when the strategy is downloaded.
Rename the PID loops so that the PID loop that is referenced by another is compiled first.
In the above example, renaming the loops in the following manner will work around the problem:
Reheat_2_Inner_Loop
to:
Reheat_2_Z_Inner_Loop
Or
Reheat_2_Outer_Loop
to:
A_Reheat_2_Outer_Loop
Opto 22 is researching this issue.
